Water Hammer - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-15-2012, 09:37 AM   #16
Where would you put water hammer arrestors in this situation: 1 2 or 3? If 2 or 3 I would use a 90 to ensure the arrestor is vertical.
brainstewn is offline   Reply With Quote
Old 06-19-2012, 12:21 AM   #17
Homerepairguy's Avatar
Rewards Points: 998
You already have one just to the left of the right hand #2. The vertical thinge.
Homerepairguy is offline   Reply With Quote
Old 06-19-2012, 02:27 PM   #18
Already have one
I plan on moving that one to a corner because it's not effective in that spot; I also want one on the cold and hot side. If this doesn't work I'm scrapping the Bosch for a navian
The Following User Says Thank You to brainstewn For This Useful Post:
Plumbinghow (06-19-2012)
Old 06-20-2012, 12:14 AM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 1,984
Lets make sure you really have a water hammer issue.
Can you describe exactly how it sounds?
Old 06-21-2012, 04:49 PM   #20
When the hot side is turned on, almost directly above the heater, the entire unit shakes and thudthudthudthudthud sound. Because of this the unit error's out 20% of the time, forcing me to reset the unit. After installed the cold side on on the horizontal pipe the errors were less frequent but it has gotten worse again.
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
big time water hammer Steelhead Plumbing 2 10-22-2009 08:34 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
