Water Going To Washer Won't Turn Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2010, 03:58 PM   #1
water going to washer won't turn off
how do i get the hot and cold water hook ups to turn off ? i was trying to hook up my washer, i just moved in. and the water was dripping on the cold hook up so i made sure it was off, but when i tried to take the hose off to hook it to washer, water went everywhere. please help
booboo313 is offline   Reply With Quote
Old 12-31-2010, 04:04 PM   #2
HVAC / Plumbing
ball valves, plug valves,, gate valves ??
kenmac is offline   Reply With Quote
Old 12-31-2010, 04:06 PM   #3
what are those and how do i fix them
Old 12-31-2010, 04:08 PM   #4
Experienced
Jackofall1's Avatar
Turn the main valve off. Once you have removed the lines you will undoubtedly will have to fix the isolation valves.
Old 12-31-2010, 04:14 PM   #5
the main valves at the wall right? if so thats what would turn off
Old 12-31-2010, 04:25 PM   #6
HVAC / Plumbing
Post a pic of the valves you are trying to turn off. You may need to use a pare of channel locks on them
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water leaking in garage everytime we use washer! Please Help shigyrl217 Plumbing 3 12-16-2007 07:03 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
