Water Goes From Cool To Hot To Hotter - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-21-2011, 08:47 PM   #1
Solutions (handyman)
Rewards Points: 364
water goes from cool to hot to hotter
We live i te country and have a well. When showering, the water starts off cool, which I understand as it has to go through the pipes from the hot water tank. Once it is hot, we turn the shower down to a comfortable lever but after about two or three minutes, the water is hot again. What could be happening? Doesn't the hot water come from the top of the tank and the cold replacement goes to the bottom?
Mark Harvey is offline   Reply With Quote
Old 06-22-2011, 06:52 AM   #2
It could be a heater problem, but if the pipes pipes are in a cool location, it could take some time for them to heat up. Water temp heat should be set no higher than 120 deg. If it continues to get too hot, reset the thermostat on the heater, and check its' operation.
You are correct in your description of how a water heater works. We usually get complaints the other way around........running out of water too soon.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
