Water To Gas Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2014, 09:23 PM   #1
Water to gas pipe
I am converting all my oil hot water radiator heat to propane. I am removing the radiator's and installing propane heaters. Can I just disconnect the radiators black iron pipes, run air through the lines till they are dry and then reuse them for gas lines once dry.
rob_010105 is offline   Reply With Quote
Old 01-27-2014, 05:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 600
Nope,... The rust, 'n crud in the pipes would plug, 'n destroy yer new heaters,...
The Following User Says Thank You to Bondo For This Useful Post:
joecaption (01-27-2014)
How to apply caulk to seal water pipe through basement wall goshenplumber General DIY Discussions 4 07-08-2013 09:40 PM
A couple furnace gas pipe questions, and an entire plan to replace my gas valve richapple HVAC 13 12-05-2012 12:33 PM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 02:53 PM
Basement drain pipe "pit" ground water fix. alecmcmahon General DIY Discussions 13 12-01-2010 06:42 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
