Old 07-09-2010, 12:56 PM   #1
Water from Furnace
Water is coming from furnace when my AC is switch ON. Would you please advice how to solve the problem?
Tarik Haque is offline   Reply With Quote
Old 07-09-2010, 03:07 PM   #2
Newbie Bill
Water from Furnace
I believe the water you are seeing is the moisture that is condensing on the coils. It is perfectly normal, however, there should be a discharge pipe (in my case it is white tubing) that the water flows through to a drain.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
The Following User Says Thank You to drtbk4ever For This Useful Post:
Tarik Haque (07-09-2010)
Old 07-09-2010, 04:21 PM   #3
Water from Furnace
There should be a drain line from the pan under the AC coil in your furnace. It is normal for water to be discharged from this drain line when the AC is operating. If you are getting water out on the floor the drain line is probably plugged and water is overflowing the drain pan. Some installations have a cleanout on the trap on the drain line. If yours does then open the clean out and probe/flush to remove the blockage. If that doesn't work or there is no cleanout the solution is to turn all power to the furnace off and remove the access panel to the AC coil and then use a probe or wire to insert in the drain line to dislodge the blockage. Use clean water to flush the line until it runs freely.
Bob999 is offline   Reply With Quote
Old 07-09-2010, 04:23 PM   #4
Water from Furnace
How can I get my drain pipe?
Old 07-09-2010, 08:18 PM   #5
Water from Furnace
If you google: ac drain line furnace
and then select "images" you'll see pages of furnaces with drain lines. One of them should help you find yours.
bob22 is offline   Reply With Quote
Old 07-10-2010, 08:31 AM   #6
Water from Furnace
Did you install the air conditioning yourself as a retrofit to the furnace? Did it ever run without leaking water all over the place? Did you ever install a drain hose or other means of getting rid of condensed water?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Water around my steam furnace Volsar HVAC 1 12-11-2007 07:40 PM
Water on bottom of furnace timkay2 General Discussion 5 10-17-2007 09:27 AM
