Water Flows Uphill? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2014, 07:16 AM   #1
water flows uphill?
Building my own home. Did the plumbing myself. Built the shower with liner and tested to make sure no leaks before putting deck mud in the liner.
No leaks, everything fine. Then...
As I drained the approx. 2" of water from the shower liner, I got a leak from an as-yet-unfinished bath tub drain. Very weird because the water would have to run against gravity to exit the tub drain line. Here's the setup:
--1.5" tub drain---------\
.................................|-----2 inch drain-----vent----trap------shower
2" vent and sink trap----|
...........................to sewer
(I notice that once posted in the discussion board, all the spaces are removed at the beginning of lines, so I added periods so you see the layout correctly. Ignore the periods.)
I was careful to allow 1/4" slope (or slightly more) per foot of run, so the water would have to run a couple of feet uphill to get out of the tub drain. In addition, I used all long sweep Ts and elbows in the horizontal runs. Any ideas what might have caused the water to backup out of the tub drain? The only thing I can think of is something caught in the line down from the T where the 2 inch shower drain meets the tub drain line. Since it's a brand new house, I was very careful not to let anything get in the lines...
Jamie
jleonardwv is offline   Reply With Quote
Old 05-12-2014, 08:14 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
Jamie
You didn't stick anything in the lines so anything wouldn't get in the lines and forget to take it out did you?
Robpo is offline   Reply With Quote
Old 05-12-2014, 09:31 AM   #3
MarginallyQualified
Rewards Points: 2,464
While you have the saw and glue out...
change that tub/shower to 2"
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
