-   -   water flow problem (http://www.diychatroom.com/f7/water-flow-problem-24337/)
copwk 07-27-2008 01:22 PM
water flow problem
Good Afternoon (at least here in my world),
I replaced the faucet in my 1st floor bathroom and am having a little issue with water flow. The cold water runs fine, no issues at all. The hot water, on the other hand, has a mind of its own. When I turn the faucet on, the water comes out with great pressure but then there is a little "hiccup" and the water pressure cuts to a dribble or cuts off.
I searched the forums and have tried several of the answers, but have had no luck. I checked the washers in the faucet (even though it is new) and all seem to be in order, I took the supply line off and ran a little water through it just in case there was something in the line and got nothing. I also tried opening the hot water faucets on every level but have not had any luck.
Any help or thoughts would be appreciated. Could be an airlock and maybe I am not trying to correct it the right way?
Thanks.
Mike Swearingen 07-27-2008 05:52 PM
There is very likely some little debris partially clogging the hot water side.
Turn the water off, dismantle the faucet, lay a towel over it and turn the water back on very briefly to flush out the faucet. Reassemble the faucet and try it out.
Good Luck!
Mike
copwk 07-27-2008 07:12 PM
darn Mike
I was hoping for something that required less work! lol, that said I will give a shot..
Thanks for taking the time,
Duane
