Water Flow/Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2008, 03:18 PM   #1
Water Flow/Pressure
Curious to know if I were to replace certain runs of 1/2" CPVC with 3/4" or even 1" if water flow and or pressure would increase at specified locations.
I'm on a well with above groung well pump. From holding/pressure tank the CPVC downgrades from 3/4" to 1/2" to cold water supply. A cold line runs to the boiler for hot water. All fittings there are obviously 1/2" copper in/out of boiler, then back to CPVC to supply HW to home.
My initial thought would be yes the water flow would increase due to larger capicity of the larger CPVC. But for hot water going through a bottleneck at the boiler from the projected 3/4" to 1/2" and back to 3/4", would flow be disturbed enough to not have a benefit of changing to larger pipe?
usmcstormvet is offline   Reply With Quote
Old 08-21-2008, 06:21 PM   #2
If you reduce the size anywhere it will reduce the flow. The pressure does not change with pipe size but may with increased flow.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 10:29 PM
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 02:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
