Water Flow Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-16-2012, 01:18 AM   #1
Water flow noise
Suddenly there was this loud water noise in the pipes without turning on any faucets. The sound level decreases if you open a faucet in the house. There is no leak anywhere that I could see. The noise went away when I turned off the main water supply valve coming into the basement. Any ideas?
Hani is offline   Reply With Quote
Old 04-16-2012, 04:14 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Check toilet flapper or fluid master/fill valve
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-16-2012, 06:04 AM   #3
Too Short? Cut it Again!
Irrigation valve opening partially?
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Another water heater noise. no_Wedge Plumbing 2 02-07-2011 10:58 AM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
water flow problem copwk Plumbing 2 07-27-2008 08:12 PM
