Water Flow Alarm Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2011, 07:17 PM   #1
I am looking for an system that will shut the water off if there is a leak. I have seen a few that have sensors you place at each water using device. However I found one that monitors for abnormal flow. It is pretty expensive though:
http://www.flologic.com/Automatic-Wa...ff-System.html
Are there any other systems like this that are cheaper?
Thanks!!
striker754 is offline   Reply With Quote
Old 03-04-2011, 06:34 AM   #2
I did not open the link, but I would think it difficult to monitor abnormal flow. When a faucet is full open, it is full open, when does this gadget consider it abnormal???
Old 03-04-2011, 07:17 AM   #3
BIGRED
Rewards Points: 252
Fire suppression systems (water) in industrial or commercial buildings do have water flow vane switches in the supply loop so the the local alarm service will know there is a problem and yes, they are expensive. You should be able to get one from a plumbing supply house. They are adjustable for flow sensitivity from full on down to a cup a minute, but they won't do much for a small leak. What you should probably look for is a small dampness detector you place on the floor just below a water fixture. It will scream if it detects a dime size puddle of water. Then if you are an electro-geek you can build up the circuit to control a solenoid valve on your main water service. You would need a detector for every H and C aperture in your home ( in my case about 20 of them) and some would have to buried in the walls -bathtubs or wall showers-. You can get them usually at a local hardware store. Good Luck.
Grampa Bud is offline   Reply With Quote
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 01:59 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
