Old 05-03-2008, 09:39 AM   #1
water filtration
I would like to install some sort of filtration system between my pressure tank and the house. Not nessasarily to make the water drinkable, but usable (remove odor and debree). Any thoughts?
tropic home is offline   Reply With Quote
Old 05-03-2008, 08:37 PM   #2
water filtration
It's really essential when you're on a private well. Cuno makes all kinds and sizes of dirt/sediment filters. Check with local distributors, though - it's best to install whatever brand they carry so you know you can get replacement filter cartridges.
Ishmael is offline   Reply With Quote
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Hot Water Cross Over rjordan392 Plumbing 3 09-11-2007 01:33 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
