Water Filters - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-15-2012, 09:17 AM   #1
Water filters
I have a large carbon filter system hooked up and there seems to be two types of filters that fit it. One where there are holes at both ends , and one that only has and inlet , with the bottom being blocked. Is there any difference , as to which one i would/should use.
ROULEAUPA is offline   Reply With Quote
Old 02-15-2012, 09:23 AM   #2
Rewards Points: 13,968
No way to tell without a picture.
Most often the indent on the bottom is to just hold the filter in place. There is no water flow through the bottom just the sides.
ROULEAUPA (02-15-2012)
Old 02-15-2012, 11:04 AM   #3
Water Treatment
Rewards Points: 900
The one with the hole running from one end to the other is solid carbon block while the other is loss carbon in the housing.
Which one is in the housing that you are replacing?
Also depends on what you are removing from the water and the flow rate that you have for the system in question.
Akpsdvan is offline   Reply With Quote
Old 02-15-2012, 08:46 PM   #4
Rewards Points: 582
seeing is believing..picture please
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
