Old 02-17-2013, 05:47 AM   #1
Water Filter Questions
Hello
Have a standard "under the sink" RO water system.
In addition to the usual filters (eg the 3 big ones and membrane), I have an Inline PH stabilizer (Pentek GS10) and a Carbon post-filter (Atoll CK-2586C). The water tastes a little bland so I just bought a mineralizer (Geyser).
1. are these last two filters necessary?
2. Is the mineralizer the last filter before the faucet. From the "blue" tube I assume yes. But just checking
Any other advice?
Thanks!
styopa is offline   Reply With Quote
Old 02-17-2013, 11:11 AM   #2
Why are you using A R/O filter?
Of course it taste bland, your taking all the minerals out of the water.
Old 02-17-2013, 11:31 AM   #3
Where I live I just need it. Any advice about my setup?
Old 02-17-2013, 12:47 PM   #4
I am far from an expert on water filters. Your set up sounds fine to me. I would put the polishers last inline as you stated. Do you have fluoride in your system? I believe you need a special filter to remove most of the fluoride. I would also add shower filters because you will still be getting a lot of chlorine while you shower as well. Or a nice whole house filter but they can be very expensive. I filter water I get from a spring thru a Berkey filter. As for your inline ph stabilzer(polisher) sounds okay , I am still up in the air on anything that changes the ph of the water. I would never go above 8.0 on drinking ph. Anything higher than that it acts more like a drug. I also would avoid anything that adds a chemical to the water to change the ph.
paintdrying is offline   Reply With Quote
Old 02-18-2013, 01:45 AM   #5
The set-ups I have seen (online) subsequent seem to place the Mineralizer before the carbon filter. Does anyone know if this is correct?
I guess I am not sure about the PH stabilizer and if that's needed. If I keep it then I I feel I h=will have too much "filter" if you know what I mean and it will slow down the process and flow.
Any other help out there?
Old 02-18-2013, 03:41 AM   #6
Water Treatment
Water quality?
Hardness, iron, and the like?
Sand in the water?
The need of filters and or ph is based on Water Need, not person need.
Akpsdvan is offline   Reply With Quote
Old 02-18-2013, 03:44 AM   #7
I live in Moscow Russia. The quality isn't very good and I assume that it has quite a bit of minerals, so I would say water is harder than normal. Considering location Im sure there is no sand. In any case, we have an RO system that pretty much filters out everything. This is why my focus is on post filters and getting a little taste back.
Thanks for your help
Old 02-18-2013, 08:49 AM   #8
http://www.amazon.com/Liqumins-Conce.../dp/B000AMUWLK
Old 02-18-2013, 10:44 AM   #9
Roofmaster
Kind of funny to take everything out, then start putting stuff back. You write very well in English, better than most US citizens that post here.
" A lot of men build things, and a lot of things fall down "
Old 02-18-2013, 10:47 AM   #10
Simply put - There was no way to filter out the "bad stuff" and leave the "good stuff". Hence the full-on RO system with remineralizer. Just installed it so lets see how it works out. The flow is restricted as I now effectively have a 6 stage process (3 heavy duty filters, Membrane filter, mineralizer, Carbon and PH stabilizer).
Old 02-18-2013, 11:12 AM   #11
Water Treatment
Very true in that if a RO system is used then it will remove 97% of what is there if it can be removed by an RO system.
And the more that you have in the water flow the lower the flow and pressure with out the use of booster pumps to bring the pressure back up again.
With the mineralizer you have more control as to what will be in the water.
Old 02-18-2013, 12:36 PM   #12
"pH stabilizers" are typically mineralizers--that is they contain calcite that gradually dissolves into the acidic product of the RO unit. It is not clear to me what additional minerals the "mineralizer" is adding or that you need both. This is particularly pertinent if you now have pressure/flow problems because of so many filters.
Bob999 is offline   Reply With Quote
Old 02-18-2013, 12:42 PM   #13
I believe the mineralizer works by gradually dissolving minerals into the water flow. As the mineral particles get very small some may escape the mineralizer cartridge and get into the water flow. Because most polishing carbon filter cartridges also include a very fine filter paper the carbon filter would capture these particles. Therefore I think you would be better off putting the carbon filter last.
Old 02-19-2013, 01:20 PM   #14
Building tradesman
Moscow, former Soviet Union, wonder what the lead content of the piping system infrastructure is?
dudleydoright is offline   Reply With Quote
Old 02-19-2013, 01:55 PM   #15
I can not image that water supply is very clean. i would say put two separate ro filter systems. Actually, I would just leave and go live somewhere else. Sounds like a fun place to visit though.
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
Whole House Filter for Well Water jfixit Plumbing 4 09-28-2011 11:42 AM
Water Softener Questions :) Einzee Plumbing 6 08-14-2011 12:55 AM
Upgrading water supply plumbing...where to locate filter? Jim S. Plumbing 3 02-06-2009 12:13 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
