Water Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2010, 04:09 PM   #1
water faucet
took water faucet apart put it back together sand now no hot wster or water pressure
marlasleeker is offline   Reply With Quote
Old 10-27-2010, 06:52 PM   #2
Rewards Points: 150
Whats the question?
braindead is offline   Reply With Quote
Old 10-27-2010, 07:12 PM   #3
If you shut the water off under the sink this could be your problem.
1. washer or pieces of washer are stuck in valve and or supply line or valve body.
2.cartridge is not installed correctly.
3.aerator clogged
good luck
plumbbum0203 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 09:19 PM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 04:16 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
