-   -   water expansion tank too close to exhaust? (http://www.diychatroom.com/f7/water-expansion-tank-too-close-exhaust-171441/)
dengle 02-09-2013 09:29 AM
2 Attachment(s)
I replaced my water heater a couple of weeks ago and noticed the cold water side was leaking a bit still. So I loosened the union and tightened the offending connection. Unfortunately, this moved the water expansion tank very close to the exhaust vent and am curious if it's considered too close? If it was simple,I'd just readjust it,but I'll have to re solder the T connection which will be annoying to say the least but doable. Here are some pics.
Attachment 65296
Attachment 65297
SeniorSitizen 02-09-2013 10:33 AM
I doubt there is a concern. After the heater has operated for a few minutes touch the pipe to test for temperature. Lick your finger like Grandma did testing the sad iron and if it sizzles then that might be too close. For a more accurate indication place a thermometer between the two or shoot it with an infrared temp. gun.
jaydevries 02-09-2013 11:01 AM
i would be more concerned if the expansion tank is supported by more than fitting
Bondo 02-09-2013 11:43 AM
Ayuh,.... I guess ya didn't use 2 wrenches, 1 to turn the nut, 'n 1 to hold the tank's position,..??
dengle 02-09-2013 01:19 PM
1 Attachment(s)
Two wrenches wouldn't work with how it was originally sweated. Everything is soldered as one piece from the water heater to the union.
Attachment 65324
oh'mike 02-09-2013 01:39 PM
You are missing the Dielectric union where the copper pipe enters the tank---
Add them now---not having them shortens the life of the tank----
jaydevries 02-09-2013 02:53 PM
now most water heaters all ready have a dielectric nipple due to unions not working as well as first thought
http://www.familyhandyman.com/diy-pr...s-busted#step8
jagans 02-09-2013 03:27 PM
Very poor looking solder joints. You may want to re-do this project when you are not in such a hurry.
747 02-09-2013 03:42 PM
why didn't you just sweat the expansion tank fitting a little bit going away from exhaust. if you look in the last pic you have plenty of room going left a little. .
AllanJ 02-09-2013 04:25 PM
No problem with the expansion tank where it is.
I would add a strap or tether to the expansion tank so it is supported by more than its T connection to the pipe. There are some conditions that are nto common but if they occur they cannot be seen (are not visible) that could result in the tank filling with water and then it is heavy enough to put strain on the T that could crack the solder and cause a leak.
dengle 02-10-2013 09:17 AM
I literally took the section of pipe that included the threaded end that screws into the heater, the T that the expansion tank is connected into and the union to the main supply and reused it on the new heater. When it was first installed, it was in the position you mentioned. However I discovered it was slowly leaking so needed another 1/4 turn which brought it to the position it's in now. I'll either need to add another union right above the heater or re sweat the T to move the tank's position.
dudleydoright 02-19-2013 02:56 PM
beware
Dissimilar metals equals electrolisis. Look it up. Correct it, and grant ye heater o2 plus h a lengthier life. Be careful screwing in that inlet as there is a plastic dip tube in that fitting. Unless it is a reverse flow model. yall
