Water In DW After Cycle - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2011, 10:30 PM   #1
Water in DW after cycle
Can make sure DW is drained, come back 30 min. later, got water in the bottom. What should I do?
fredec is offline   Reply With Quote
Old 09-27-2011, 03:28 AM   #2
The drain hose must go up to the top of the machine before it connects down to drain.
Jim
jamm51 is offline   Reply With Quote
Old 09-27-2011, 06:28 AM   #3
Rewards Points: 1,216
I believe most dishwashers have a little bit of water left in the bottom after a wash cycle to keep the bottom seal moist so it don't dry out. Not completely sure about that though wait until you hear other replies.
COLDIRON is offline   Reply With Quote
Old 09-27-2011, 09:01 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Do you notice that the soap is not being used up completely like it's just running down the inside of the door? Mine did that a little, and told my wife (new house to us) that I probably needed to loop up the drain hose. I checked and it was okay. A couple weeks later it stopped using the soap all the way. I ended up having to pull the pump screen out and clean it. It was clogged with all kinds of greasy cheesy looking crud. Works great now.
Journeyman Plumber
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
