Water Droplets On Cold Water Pipes In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2013, 09:06 PM   #1
water droplets on cold water pipes in basement
how do I eliminate the sroplets that have just appeared on only the cold water pipes leading from the main water pipe to the water heater in the basement? What caused these droplets on the outside of the cold water pipes?
mmmandj is offline   Reply With Quote
Old 03-09-2013, 09:33 PM   #2
Water Treatment
Rewards Points: 850
Moisture in the air and really cold pipes... Go to the box store and get the size of black foam to put on your cold water pipes. They come in 1/2 ,3/4 and 1" some of them you have to cut too open and some come already open just peal the tape cover off and they seal closed.
Akpsdvan is offline   Reply With Quote
Old 03-09-2013, 09:36 PM   #3
DIY staff
Rewards Points: 7,174
Also---run a dehumidifier in the basement----that excess moisture can cause trouble with the flooring in the rooms above the basement----
Old 03-10-2013, 03:08 AM   #4
Water Treatment
Rewards Points: 850
And what part of the country this is going on i.... I know that here in Alaska there are places that do and places that don't..
Is it a little or is it pouring off the pipes?
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Help! Yellow Hot Water mechetti Plumbing 1 11-01-2012 08:57 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Water pipes behind basement insulation ariapn Remodeling 6 04-02-2010 09:28 PM
