Water Dripping From Vent Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2010, 09:02 PM   #1
Water dripping from vent pipe
Hi,
I recently removed my laundry pump in my basement. At the time, I did not have a proper cap to cap the vent pipe, so I temporarily covered it with a clear plastic bag until I could get a proper cap.
When I went to install the proper cap, I noticed that water had accumulated in the plastic bag. Is this rain/snow water that is making its way down through the vent pipe on the roof, or is it just condensation from some air getting up into the pipe? I would hate to cap it just to have it fill up with water.
Rosy
Rosy_55 is offline   Reply With Quote
Old 01-06-2010, 09:37 PM   #2
Do something
D'Brie's Avatar
Warm air inside your home rises up through your vent pipe. Once outside and trapped by the plastic bag it cools and condenses.
D'Brie is offline   Reply With Quote
Old 01-06-2010, 10:52 PM   #3
Sorry, maybe I wasn't clear when I described it. The bag is actually inside the house in the basement covering the vent where it went into the old laundry pump. The vent on the roof is free to breath as it should be.
I know I need to cap the vent in the basement (not really into the methane gas in the house idea), but I'm not sure if I can just cap it where it went into the old laundry pump, or if I need to re-route the vent pipe somewhere else.
sorry for the really dumb question.
Rosy
Old 01-07-2010, 10:00 AM   #4
Guessing that the water is condensation. The air in the house is warm and is meeting colder air from outside (coming into the pipe) and causing it. Your cap should be fine. The vent is also a part of the main drain and the water should leave the house the same as all other drains.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-07-2010, 10:35 AM   #5
Awsome, thank you very much.
Rosy
Frozen Vent Pipe Ratchye Plumbing 55 Yesterday 06:21 PM
Amp meter Results - SE Cable Bad or Power CO jamiedolan Electrical 30 01-23-2009 01:16 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
