Water Draining From Toilet Bowl - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-03-2014, 08:58 PM   #1
FClef's Avatar
Rewards Points: 160
My girlfriend lives in a mobile home and she has one toilet that the water keeps draining from the bowl, yet the tank stays filled and the toilet is not running. The home is on a foundation and there is no visible water leak in the basement. When the bowl drains there is an overwhelming odor of sewer gas.
I know that this sounds like a blocked vent pipe. I have never cleared a vent pipe before and her father is likely to be the one to fix it, but it may be a few days until he is able to do it. Since the water keeps draining from the bowl, is there anything that can be done to keep the sewer gas from coming back into the home until this is fixed properly?
"Human beings can always be relied upon to assert, with vigor, their God-given right to be stupid"
Dean Koontz - Seize The Night
FClef is offline   Reply With Quote
Old 02-03-2014, 09:40 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You could stuff a rag down it, but be careful not to flush it.
If she lives in a mobile, there may be no vent, or there may be an "air admittance valve" hidden in a wall somewhere that has failed.
Anything is possible as far as plumbing goes when you start poking around a mobile....
The other alternative is that the toilet has something stuck in it and is causing the water to slowly siphon out.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
jmon (02-03-2014)
Old 02-03-2014, 09:59 PM   #3
Rewards Points: 276
Alan, although not very likely, but is it possible there could be a hairline crack in the trap of the toilet itself causing the water to leak out?
jmon is offline   Reply With Quote
Old 02-03-2014, 10:25 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 664
This is possible but the water would most likely appear on the floor as if the wax had failed
The Following User Says Thank You to TheEplumber For This Useful Post:
jmon (02-04-2014)
Old 02-04-2014, 07:56 PM   #5
Rewards Points: 1,948
Was the home remodeled?
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Toilet Bowl Rim Leak Msnbcjunkie Plumbing 8 10-13-2011 01:31 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 03:00 PM
