Water Draining Into Toilet Bowl But Not From Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-24-2012, 07:05 PM   #1
Water draining into toilet bowl but not from tank
Hi everyone...this is my first post of searching and not finding an answer to my toilet issue. Couple weeks ago I noticed water running into the toilet bowl in streams from the front and along the right side of the bowl. No water streams from the left side. I turned off the water supply and left it overnight and the tank would drain. I replaced everything in the tank: the ballcock, overflow tube, flapper, float, and also the tank to bowl gasket. After re-assembling everything I still noticed the water streams just that they were very small now.
To narrow it down I put some blue food coloring in the water tank and waited to see if the water streams would be blue. After waiting almost 1/2hr the water was still clear. I flushed the tank and removed the flapper and used a small mirror to see if water was dripping from the refill tube's thread, but saw nothing. I dropped some red food coloring in the flapper's drain which still had some water in it (back of the toilet bowl if that makes sense). I monitored the streams in the toilet bowl and sure enough they were red! Is this something I should be worried about? Or as long as water is not leaking from the tank itself I'm fine?
black00 is offline   Reply With Quote
Old 08-24-2012, 07:24 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
It has to be coming from the tank. There is no other supply. Worry- you are paying for that water.
Coastal South Carolina
Old 08-24-2012, 08:32 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
air gap the over flow tubeName:  images fmr.jpg
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-25-2012, 04:20 PM   #4
It could be that your flapper is not sealing tight - did you get the right size? Also - did you change out the valve seat? It is a larger gasket ring that sits around the flush valve. This part failed on me before and caused the slow leak.
wassermeister is offline   Reply With Quote
The Following User Says Thank You to wassermeister For This Useful Post:
plummen (09-19-2012)
Old 09-19-2012, 04:27 PM   #5
tank leaking
Originally Posted by Javiles View Post
air gap the over flow tubeAttachment 56247
how do I air gap over flow tube ? Can' tell by the picture.
brokeit is offline   Reply With Quote
Old 09-19-2012, 08:02 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Try scuffing up the area the flapper seats against a little get the crud off of it.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 09-19-2012, 08:28 PM   #7
Rewards Points: 582
sounds like you need a new flushvalve assy...thats the part the flapper is hooked to....
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet tank to bowl issue. Possibly defective batch? Dr_Jim Plumbing 0 01-18-2010 05:44 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
