-   -   Water draining into toilet bowl but not from tank (http://www.diychatroom.com/f7/water-draining-into-toilet-bowl-but-not-tank-154749/)
black00 08-24-2012 08:05 PM
Hi everyone...this is my first post of searching and not finding an answer to my toilet issue. Couple weeks ago I noticed water running into the toilet bowl in streams from the front and along the right side of the bowl. No water streams from the left side. I turned off the water supply and left it overnight and the tank would drain. I replaced everything in the tank: the ballcock, overflow tube, flapper, float, and also the tank to bowl gasket. After re-assembling everything I still noticed the water streams just that they were very small now.
To narrow it down I put some blue food coloring in the water tank and waited to see if the water streams would be blue. After waiting almost 1/2hr the water was still clear. I flushed the tank and removed the flapper and used a small mirror to see if water was dripping from the refill tube's thread, but saw nothing. I dropped some red food coloring in the flapper's drain which still had some water in it (back of the toilet bowl if that makes sense). I monitored the streams in the toilet bowl and sure enough they were red! Is this something I should be worried about? Or as long as water is not leaking from the tank itself I'm fine?
rjniles 08-24-2012 08:24 PM
It has to be coming from the tank. There is no other supply. Worry- you are paying for that water.
Javiles 08-24-2012 09:32 PM
1 Attachment(s)
air gap the over flow tubeAttachment 56247
wassermeister 08-25-2012 05:20 PM
It could be that your flapper is not sealing tight - did you get the right size? Also - did you change out the valve seat? It is a larger gasket ring that sits around the flush valve. This part failed on me before and caused the slow leak.
brokeit 09-19-2012 05:27 PM
tank leaking
how do I air gap over flow tube ? Can' tell by the picture.
plummen 09-19-2012 09:02 PM
Try scuffing up the area the flapper seats against a little get the crud off of it.:)
ben's plumbing 09-19-2012 09:28 PM
sounds like you need a new flushvalve assy...thats the part the flapper is hooked to....:yes:
