-   -   Water and Drain Line Location (http://www.diychatroom.com/f7/water-drain-line-location-13761/)
Material Tester 11-25-2007 06:06 PM
Hey All,
Just a quick question regarding new sink drain and water services.
I am installing 2 - sinks where there was none and need to know if there is a typical rough height for the drain and water lines from the floor. Also I wanted to know if there is "typical" spacing for these items from each other. I am thinking that this is somewhat of a "typical" dimension.
I installed a similar setup in the second floor bath and found that I had to add an extension to the drain line and the shutoffs seemed cramped.
Any help would be appreciated.
scrapiron 11-27-2007 08:40 PM
Drain, about 17 inches from floor with a 4 in. offset from center line depending on the location of the trap. Supply lines 6-8 in. from center line roughly 2-3 in. above drain keeping in mind ease of service in the future.
