Water Coming Up Water Supply Liner - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-30-2009, 09:05 AM   #1
water coming up water supply liner
Hi
My girlfriend has water(clear) coming up the liner (PVC conduit) that lines the blue flexible water supply line from the town water supply. I called a plumber but he has no idea why except maybe a drain tile issue. I looked under the plate for the sewer clean out (a few inches away) but no water issue there. Could the town have a slow leak in the water system? I have never seen this before. Anyone experience this before?
candaneh is offline   Reply With Quote
Old 03-30-2009, 09:37 AM   #2
HVAC / Plumbing
If I'm understanding your question.. This is the supply line that feeds the house & it's leaking through a PVC casing that the supply runs through ? If this is the case & it's below grade outside.. the installer probably didn't seal off the casing it's probably ground/ rain water is comming in . You will have to dig up outside & seal the casing
kenmac is offline   Reply With Quote
Old 03-30-2009, 09:46 AM   #3
Thank you for the fast reply. You understood my question correctly and your answer makes good sense. The house is only 2 years old and possible coverage if the casing was not properly sealed.
Old 03-30-2009, 09:50 AM   #4
HVAC / Plumbing
Like I said... You will have to dig up the line outside & seal ... Silicone usually does the trick. Let it dry b-4 you cover it
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Can water supply pipes be PVC?? i need general help... hallbum Plumbing 5 12-10-2005 01:22 AM
