Water Coming Up Through Sink In Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 05:47 PM   #1
Water coming up through sink in basement
When we pull the plug on our kitchen sink after doing dishes we get some of the water coming up through a sink in the basement. Does this mean the main line is partially clogged or do I need to change the plumbing on the basement sink so it ties in higher on the main drain line?
bunjr is offline   Reply With Quote
Old 01-31-2012, 05:49 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
YOu have a clog
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 01-31-2012, 07:26 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
May not be the main, could be the branch line that serves the sinks. Need to see you layout to be certain.
Old 01-31-2012, 07:33 PM   #4
Rewards Points: 582
yes you have a clog in the line to kitchen sink that must have basement sink on same line ...may not be main line ...pictures would help...
Water coming up through cracks in basement rockarmygreen Flooring 11 04-09-2015 10:26 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Water coming in under basement door lucaduc General DIY Discussions 3 07-28-2011 07:48 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
