Water Coming In Under Bathtub - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2009, 06:56 AM   #1
Water coming in under bathtub
I have a bathtub that the backside is against the garage wall. Ive been noticing water puddling in the garage against this wall. I cut a small piece of sheetrock off to look inside the wall to see where the water was coming from and think that it may be coming up around the bathtub drain. I have a concrete slab foundation and the house is only 9 years old. I've been trying to keep an eye on it to see when theres more water, it seems as if after a storm theres more water there. Is it possible that the storm water is coming up through the area around the drain for the tub? If so, how can i fix it?
thesinks is offline   Reply With Quote
Old 07-04-2009, 08:14 PM   #2
test
set shallow bowl in hole in the concrete. weight it down so it will not float. keep an eye on it. if the bowl fills you have surface water issues. then you need someone who does waterproofing. if not then you have a leak. then you need a plumber. breid
breid is offline   Reply With Quote
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Furnace troubles, where's the water coming from... Head Scratcher HVAC 10 03-23-2008 07:40 PM
