Old 11-07-2009, 02:07 AM   #16
Originally Posted by plumber Jim View Post
Ok, your problem is that you have used a supply line to feed the spout. If I was looking at that correctly. Hard pipe it and you should be good. You should also consider removing those other sink faucet supply lines and pipe it correctly.
I can use hard line from valve to spout but no way in the world I can use hard line from PEX to valve.....unless I replace the entire length of PEX tubing.....that is not feasible....there isn't enough slack to move PEX and lack of space.....it does looks like I have room in there but there isn't......like I mention before...it is hacked job....have you seen the size of the hole....YIKES.....
BigWalt is offline   Reply With Quote
Old 11-07-2009, 02:11 AM   #17
That looks like Grey poly pipe not Pex. But start with the spout and you will see that it works better.
plumber Jim is online now   Reply With Quote
More On This Topic
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 3 in installing a ball valve. For this step, I will be marking and cutting my ball valve. On our ball valve, our pipe will stick inside of the valve on each end... Read More »
We're hooking up the angle stops for the water supply to the sink right now. I've got the cold water side done and now I'm going to do the hot water side. I've got to cut this cap off the copper pipe and then fit the valve onto the pipe, so, let's go... Read More »
We are going to talk a little bit about how we are going to get water to our shower, our toilet, our new washing machine, and our sink. What I had to do was I had to find a place where I could pull cold water and also pull hot water and being that these... Read More »
I’m Lee. I have a degree in architecture and about ten years construction experience, and we’re installing a new dishwasher. The water inlet, which is, everything’s located on the bottom. You just want to take some Teflon tape and... Read More »
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 03:59 PM
toilet water coming through the shower drain princessdniez Plumbing 6 05-31-2009 06:19 PM
Gas Hot Water Heater Tank and Pressure Relief Valve skadoo323 Plumbing 0 01-12-2009 10:52 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 10:07 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
