Old 11-03-2009, 04:21 PM   #1
Default Water coming from shower head...
I got problem here and I can't figure it out....
Recently I replace tub / shower faucet assembly. It is single lever faucet assembly.
Water is coming out from shower head when filling the tub.
I've had pressure valve taken apart few times, I don't see anything wrong with it.
I did remove the spout, hoping it would be restricted but it made no differences.
I did swap shower head, same results......
Now what????
by the way, it didn't do that before and the main reason to replace the faucet assembly is because the valve itself is leaking.
BigWalt is offline   Reply With Quote
Old 11-03-2009, 05:44 PM   #2
Your valve body is up-side down
gjp31254 is offline   Reply With Quote
Old 11-03-2009, 05:50 PM   #3
really?
I install it correctly....
the letter cast on the pressure valve said shw, tub, cold and hot.
shw goes on top...correct...
Old 11-05-2009, 01:55 AM   #4
What brand faucet and what kind of pipe did you run from the faucet to the spout?
plumber Jim is online now   Reply With Quote
Old 11-05-2009, 02:49 AM   #5
American Standard...Williamsburg trim
The pipe is the same, I haven't change the pipe...it is combination of PEX tubes and flex hoses.
The flex hose runs from bottom of pressure valve to spout.
FYI...whole house water line is PEX tubing....that's the way it is in North Carolina.
Old 11-06-2009, 12:14 AM   #6
that flex hose is more than likely restricting the flow to the spout causing some of the water to go to the shower head. have any pictures of the pipe?
Old 11-06-2009, 12:36 AM   #7
same hose with old faucet assembly......why would it be insufficient with new faucet assembly?
I'll post picture(s) tomorrow.
Old 11-06-2009, 12:43 AM   #8
you should have a full 1/2" ID from the valve to the spout. Anything less than that and you run the risk of water pushing back up to the shower head. you should hard pipe to the spout always.
Also, When you say hose you don't mean a supply hose like used to supply a sink faucet do you? If so then that is a big no no.
Old 11-06-2009, 12:52 AM   #9
It is full 1/2"....I did measure the ID. My first thought was the line too small but............
May I ask why?
Just curious, the hoses were there before I bought the house 3yrs ago.
Anyway, Are the supply hose to cold side and hot side of valve ok???
Old 11-06-2009, 01:10 AM   #10
May I ask why?
Supply lines are designed for sink faucets and should not be in the walls.
What kind of hose are you talking about going to the spout? even pex to the spout could have a restriction in the fitting itself not the pipe.
As far as why your last valve didn't do it i don't know. It could have just been more forgiving and just got lucky.
Old 11-06-2009, 01:25 AM   #11
Ok, they are not in the walls, they're in open space behind tub / shower wall....I'll post picture, so you'll see what I mean.
The whole house is plumbed with PEX. I hate that chit. I rather have copper pipes but it is not feasible for me to change entire water lines right now.
The PEX lines and fittings are not restrict....trust me on that but I understand what you're saying.
Here's what I am going to do....remove flex hose from pressure valve to spout, install 1/2" copper pipes with proper fittings from pressure valve to spout and then go from there.
Join the club....wait until you see the pictures, whoever did this in first place is a butcher....My gosh, what a hack.
Old 11-06-2009, 01:34 AM   #12
The pex is fine on the hot and cold supply to the tub/shower valve. you just want 1/2" brass or copper from the vlave to the spout.
Old 11-07-2009, 12:10 AM   #13
Did you take those pictures?
Old 11-07-2009, 12:39 AM   #14
The picture below...new valve assembly in over size [hacked] hole....
The picture below...you can see the PEX lines and flex hoses....I didn't have the chance to correct the line from valve to spout...
Picture below...finish product...PITA with oversize hole....not that easy to line up the trim plate....
Old 11-07-2009, 01:27 AM   #15
Ok, your problem is that you have used a supply line to feed the spout. If I was looking at that correctly. Hard pipe it and you should be good. You should also consider removing those other sink faucet supply lines and pipe it correctly.
More On This Topic
Faucets should accentuate the overall appearance of your bathroom. You can choose from a large selection available at hardware stores, home centers, bath remodeling showrooms and plumbing wholesalers. You can also shop online. Whether you are replacing... Read More »
With today's busy schedules, it's difficult to find time to relax and pamper yourself. But you don't have to go to a vacation resort to feel spoiled. By installing a multi-head shower, you can turn your own shower into a mini-spa. Read on to learn how to... Read More »
Today we’re installing a kitchen sink in a rebuilt counter. We already have the sink secured with the braces and everything. The next step that we want to do is to actually install the sink supply lines onto the faucet valves. You want to loosen... Read More »
Bathrooms have become a critical first stop for prospective home buyers in today's competitive real estate market, and a bathroom remodeling project can increase your home's value-and its desirability-among home shoppers. Creating a professional looking... Read More »
Hey everybody, Don Golden for Expert Village and we are back in the shower here and what I want to do is show you how the shower works and the valve that we are going to have to take apart here to stop this nasty leak. Now if you look at the way this is... Read More »
Price Pfister 3 Valve Shower Replacement water issue LeviDIY Plumbing 3 06-18-2009 03:59 PM
toilet water coming through the shower drain princessdniez Plumbing 6 05-31-2009 06:19 PM
Gas Hot Water Heater Tank and Pressure Relief Valve skadoo323 Plumbing 0 01-12-2009 10:52 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 10:07 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
