Water Collecting Around Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-26-2011, 01:59 PM   #1
No matter how many times i try to readjust the bathroom sink drain, water collects around the base of the drain. It seems almost impossible to keep the top level when tightening the pipe. Could it be that the sink hole is not perfectly beveled? Its an undermount sink if that makes a difference. I thought sinks had universal drain holes. Or is this normal?
navman28 is offline   Reply With Quote
Old 12-26-2011, 03:36 PM   #2
DIY staff
Rewards Points: 7,174
You may have a lousy pop-up drain assembly---the good ones have a nice thin brass (chrome plated?) sink drain piece --The bad ones use plastic with a stamped metal covering-
What do you have?
Old 12-26-2011, 08:16 PM   #3
What do you have?
I have the plastic with stamped metal covering. After I was looking at it again that is exactly the problem. I took the stamped metal cover off and put just the plastic in and it fits perfect. Looks like I am going to get better ones tomorrow. Any recommendations?
Old 12-26-2011, 08:21 PM   #4
Rewards Points: 582
most of the good one comes with the complete faucet like delta...however look for the metel ones they are all better than the plastic ones...
The Following User Says Thank You to ben's plumbing For This Useful Post:
navman28 (12-26-2011)
Old 12-26-2011, 08:24 PM   #5
DIY staff
Look for the replacement at the Home Depot--they used to have a nice brass one for about $12--
Blue and white cardboard box--I hope that the still have that one--it worked well--
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 02:30 PM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
