Old 05-17-2007, 03:53 AM   #1
Default Water from cold water faucet goes from cool to hot to cool
With summer almost here, I've noticed that water from my cold water faucets starts out cool, then after a few seconds, it becomes rather hot and stays that way for maybe 20 sec before becoming cool again. I guess this is due to the main water line for the house being routed through the uninsulated attic above the garage. Is insulating this line likely to help? If so, what are my insulation options?
tima2381 is offline   Reply With Quote
Old 05-17-2007, 07:51 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You can get foam snap-on pipe insulation or lay batts of regular insulation (kind with no vapor barrier on it) over the pipe or both. I would do the latter.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-17-2007, 01:19 PM   #3
Good luck!
Mike
Just to be clear, by "latter" do you mean "both" or just batts?
Also, I don't know why you would or wouldn't use vapor barrier insulation for this. Could you expand on that?
Old 05-17-2007, 05:40 PM   #4
Good luck!
Mike
Mike , Are you related to one of my customers, Tony Swearingen ,here in Marianna Fl. just wondering I see you in here alot .
tzzzz216 is offline   Reply With Quote
Old 05-21-2007, 10:04 PM   #5
Tima2381, you probably need to install a "heat trap" in the cold water piping that supplies the water heater. Drop the cold water feed down 12", then back up again just before it enters the water heater - put a drain at the bottom of the loop/trap. The other way is to just install a swing check in the line.
Ishmael is offline   Reply With Quote
Old 05-22-2007, 02:02 AM   #6
You are talking way over my head. From what I can tell, it definitely seems related to the outdoor temperature. It didn't happen during the winter, and it improves at night. The main water line into the house is 30' of bare PEX running across uninsulated (garage) attic space, which would seem to explain it, given how hot the attic becomes during the day.
Old 05-22-2007, 10:02 AM   #7
Yeah...if it wasn't a problem in the winter, you're probably correct.
More On This Topic
We did here in our houses. We have the good insulation but it was not good enough for me. So when we got all these packages from the company's with all these Styrofoam chips in there, we used these chips and put them on top of the ceiling and add to the... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. We are looking for R-Value. It's the same thing up here in our ceiling. Okay if the... Read More »
So what you see here is our water heater. And this water heater is a big one, because we want to store as much water as possible when we get the hot water from the sun. If you would use only a 10 gallon or a 20 gallon water heater, and we take a shower... Read More »
How to Use Dry Ice
How to Use Dry Ice by eHow.com
Dry ice is solid carbon dioxide that forms when some refrigerated liquid carbon dioxide vaporizes, leaving behind solidified carbon dioxide with the texture of snow. The dry ice available to buy is this "snow" compressed into either pellets or bigger... Read More »
H,i I am David Belch and today I am with Expert Village to show you how to install windows. I take my window here and slide it all the way to one side. You take the insulation and peel the insulation into pieces. You slide the insulation in. You want to... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Faucet options for undercounter water filter mdr25 Plumbing 4 03-02-2007 06:56 PM
Little to no water pressure egglesh Plumbing 7 02-19-2007 08:42 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 10:05 AM
hot water effecting cold water pressure hp1964 Plumbing 1 06-23-2005 06:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
