Water From The Center Of A Shower Head - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2013, 05:43 PM   #1
Rewards Points: 91
water from the center of a shower head
Guys - having some trouble and looking for guidance.
A couple of months ago I purchased and had installed what I think is a good quality Hansgrohe shower system, the Croma Green Showerpipe. Initially, it worked just as it should - but I noticed after a few weeks, a heavy drip coming from the center of the rainhead shower head. The drip would only occur when the shower was on, it stopped as soon as you turned it off. It didn't initially bother me, but the drip has gotten faster over the last few weeks, and has now become a fairly constant stream of water - again, only when the shower is in use. It detracts from the shower, as it is a lower pressure stream, and heavier then the flow from the regular shower spouts.
I took a look up close at the area while the shower was not in use - the very center of the shower head appears to have a star shaped screw in it. The water must be coming around that screw. I have the right size screw driver bit, so i thought perhaps it was lose - I went to give it a turn, but it only moved very slightly, it wasn't particularly lose, and i didn't want to force it tightly should i cause any damage. The sligth turn i made didn't impact performance, and it continues to flow water from the center of the shower head.
Does anyone have any thoughts over why this would happen and what my possible cause of resolution might be? It was an expensive system to purchase, so I'm expecting it should perform better.
thanks,
Matt
mmhendrie is offline   Reply With Quote
Old 09-24-2013, 06:27 PM   #2
I think you might have a bit of garbage inside the showerhead.
I'd probably loosen the screw, take it apart, clean it, and put it back together.
Unless: you says it was fairly new. Check to see if doing so voids your warranty.
If so, you could screw in a temporary showerhead while that one is sent back, or whatever warranty requires.
RoyalAcresRod is offline   Reply With Quote
Old 09-25-2013, 11:21 AM   #3
Rewards Points: 91
thanks - that did it!
Old 09-25-2013, 11:29 AM   #4
Glad to hear it! I always seem very capable of dislodging some mung and causing what happened to you when I decide to do some plumbing work ...
Old 09-25-2013, 06:01 PM   #5
Rewards Points: 2,034
I hope you did not let us down and forget to show the plumbing butt crack...
Bathtub faucet won't stay depressed to direct water to shower head ferrugia Plumbing 13 02-27-2013 09:39 PM
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 06:47 PM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
What is the standard method of water pressure test for shower plumbing please? Andy21 Plumbing 10 10-28-2011 04:06 AM
Water coming from shower head... BigWalt Plumbing 16 11-07-2009 12:11 AM
