Water Box Under Bath Tub Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-07-2009, 05:59 AM   #1
LPR
Water box under bath tub rough-in
Hello there: I recently bought a new house with a bath rough-in in the basement. I'm getting ready to finish the bathroom. The bathtub drainage is in a square hole (approx. 12 in. deep) that is full of water - seems to be ground water. I tried emptying it up, but keeps getting full. What is this? Does is stay there under the bathtub? Do I need to cover it or seal it? Will it cause water problems down the road? Thanks in advance for any advice!!
LPR is offline   Reply With Quote
Old 10-07-2009, 06:14 AM   #2
That sounds like a sump for the floor perimeter drain, not a sewer connection. And it sounds like you could use a sump pump.
Old 10-07-2009, 06:31 AM   #3
if it is a box where a shower or tub can be installed in the future it is a p trap for that. i usually don't glue these fittings so they can swivel and adjust to whatever is used. i am bad about just taping the top before i cover it with dirt. this will hold some water but time will create a leak. the plumber should have sealed this good if he knew it was for future use. sounds like sewer water to me. it might be water coming from another tub or possibly a sink. that may be why it looks clean and doesn't smell. use care anyway.
buddy builder is offline   Reply With Quote
Old 10-08-2009, 03:35 PM   #4
LPR
Thank you all! I'm a little confused with the whole thing... I think I need to call the builder.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 03:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
