Old 10-05-2009, 04:07 PM   #1
LPR
Question Water box under bath tub rough-in
Hello there: I recently bought a new house with a bath rough-in in the basement. I'm getting ready to finish the bathroom. The bathtub drainage is in a square hole (approx. 12 in. deep) that is full of water - seems to be ground water. I tried emptying it up, but keeps getting full. What is this? Does is stay there under the bathtub? Do I need to cover it or seal it? Will it cause water problems down the road? Thanks in advance for any advice!!
LPR is offline   Reply With Quote
Old 10-06-2009, 03:24 PM   #2
You'd be better off posting this in the 'plumbing' forum. You'll probably get an answer there.
Good luck with your bathroom.
gma2rjc is offline   Reply With Quote
Old 10-07-2009, 07:46 AM   #3
LPR
Thanks!! Will do.
More On This Topic
Our raised bed situation here is different from some. Although any raised beds container that would potentially hold water is going to have the same problems we have here with this bathtub. Bathtubs obviously are made to hold water for peats sake, and... Read More »
Ok, next, let's come to some bath wear. The first one I would like to teach you is the bath tub. Yu gang. Yu in Chinese, it means bath, gang tub, so very easy to understand, because yu means bath, so it has the water radical and this is the last part... Read More »
Hi, my name is Lanie McCormick I'm a fine art photographer in Austin, Texas. I'm here to show you how to set up a dark room on behalf of Expert Village. In setting up the wet workstation in your darkroom there are several options that you can consider... Read More »
Hi, I'm Liz Hood on behalf of Expert Village and right now I am going to be talking about certain things that you will need to buy to give your new baby a bath. Now, this right here is a baby bath tub. It has a little duck hammock drapped across the top... Read More »
Do you want a relaxing bath with lots refreshing bubbles? Then follow these instructions and you will have it in no time. Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 11:31 PM
No Hot Water comeing out of Faucets gangstacro Plumbing 5 11-30-2008 05:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 11:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
