Water Box - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2012, 07:02 PM   #1
Rewards Points: 248
Water Box
The water meter box that connects to the county water district is concrete. It has a metal flap on top. The metal flap has a tiny vent about 1/2" x 1" in size. When it gets wicked cold in the winter temperatures typically drop to 20F. I'm wondering what is the need for the air vent? Why does the water district not worry about freeze damage to the valves that are exposed to air through the vent? The valves are metal, possibly brass. Water pipes need to be buried 18 inches to avoid freeze damage but the main valve is exposed to cold air outright.
I suspect that when the valves freeze they end up leaking not breaking. A leaking valve will harm the customer but not the water district. So the water district doesn't care.
jackwashere is offline   Reply With Quote
Old 10-03-2012, 07:10 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
That "vent" hole is great for getting the top open
If your worried about it freezing, fill the box with insulation.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
