Old 10-21-2012, 01:55 PM   #1
Water Boss Softener HO
My unit seems to keep regenerating non-stop.
When I unplug and plug back in it shows "HO"
A few seconds later then "1" blinking and it is regenerating.
And suggestions?
theedudenator is offline   Reply With Quote
Old 10-21-2012, 02:05 PM   #2
Water Treatment
Make sure that the controler is snapped all the way to the left.
If the control is not making contact with the cam wheel it will not know when to stop and just continue to cycle
Akpsdvan is offline   Reply With Quote
Old 10-21-2012, 02:14 PM   #3
I checked that already.
The magnet assembly rotates and pushes the plunger in and out.
it is currently flashing "2"
Powerclean is on - I cannot turn it off? Maybe cause it is regenerating?
Old 10-21-2012, 02:42 PM   #4
Water Treatment
How often is it cleaning?
There is a 96 hour cleaning setting that will start a regeneration Every 96 hours.
I know it is the weekend, but have you tried the 800 number on the back of the manual?
Old 10-21-2012, 03:00 PM   #5
I took apart what I could and cleaned everything.
Now it seems like it is normal.
Not sure on the 96hour setting. I need to read the manual to see what is better.
I think the plunger in the valve that the magnet rotates against is corroded and hard to push in.
I tried to clean it. I might need a new one.
Old 10-21-2012, 03:21 PM   #6
Water Treatment
Age of the unit?
Water quality that the unit is dealing with?
It is possible that the drive end cap might be in need of replacement.
It can be had with out the motor or the magnet wheel, then just move the ones that you have to the new assembly.
Old 10-21-2012, 04:29 PM   #7
8 years old.
Moderate hardness with decent amount of iron.
It seems like a use alot of salt in this unit.
Not sure if it is worth putting any $$ into it.
Are there better units out there? Compared to this model 900?
Old 10-21-2012, 04:48 PM   #8
Water Treatment
When did it start using more salt?
The drive end cap most likely would be under 150.00
There are units that are cheep so that it is cheaper to replace than rebuild.
Water Softeners rickglarson Plumbing 1 01-09-2012 05:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 11:48 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
