Water Bill - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2008, 03:38 PM   #1
water bill
we have cleveland city water.our latest bill just went up almost 400% !!!! It said my family of 3 used 600 gallons of water per day for the last 3 months. service man was here and found no leaks. How is this possible.Could the meter go bad and over read the water usage?
johnrem is offline   Reply With Quote
Old 03-28-2008, 03:40 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
If you walk out and look at the meter, can you see any dials spinning or moving, if you see movement, then you have a leak somewhere, and leak in ground might not be visible.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-28-2008, 03:46 PM   #3
no ..service tech was here...meter did show flow,but I shut off supply to the humidifier and all the dials on the meter stoped.tech confirmed no leak
Old 03-28-2008, 03:48 PM   #4
my son takes long showers but dang,we only have 40 gal. of hot at a time.
Old 03-28-2008, 03:49 PM   #5
Journeyman Plumber
Originally Posted by johnrem View Post
meter did show flow, but I shut off supply to the humidifier and all the dials on the meter stopped.
Humidifier Is this always running? Could that be your cause?
If not maybe the meter reader got the numbers all wrong.
Old 03-28-2008, 03:58 PM   #6
aprilaire on the furnace.only runs when the furnace runs .set at normal range.no sweaty windows.what kind of flow would you need to get 400 plus gallons of water per day more than usual,and why don't I see this water?
Old 03-28-2008, 04:06 PM   #7
Journeyman Plumber
Less the 1 gal a min.
Do you have a clean out on the mainline outside where you can open it up and look for water flow down it?
Old 03-28-2008, 04:11 PM   #8
Journeyman Plumber
A little more then .27 gals per min in 24 hours period.
Old 03-28-2008, 04:18 PM   #9
we do have a clean out outside.I will check it out.
Old 03-28-2008, 04:30 PM   #10
No water flow at the outside cleanout at this time.Is it possible that the meter is defective,and reading more water than what we are using?
Old 03-28-2008, 04:49 PM   #11
Send a message via AIM to Marlin
I've never seen it before but it could be possible. Call the water district, explain the situation and have them send someone out there to check it out.
Marlin is offline   Reply With Quote
Old 03-28-2008, 05:29 PM   #12
Journeyman Plumber
Yes call and have them check it out or have them switch it out.
Old 03-29-2008, 08:28 PM   #13
Put food coloring in all your toilets. you may have a bad flapper. it will only run when the water drops enough to trip the balcock. you may have missed that. put some food coloring in the tank of your toilet and wait and see if the color bleeds into the bowl..
http://www.broomfieldplumber.com
plumber Jim is offline   Reply With Quote
Old 05-01-2008, 01:59 PM   #14
turns out ,the city was getting bad readings for the last 3 Quarterly bills and I was under billed so they make it up all at once..we did have a price increase at the start of '07 so I didn't notice the under billing because the bills stayed close to the same.They use a remote and read as they drive by.
Old 05-31-2011, 09:00 PM   #15
Rewards Points: 12
Sorry, I am bringing this thread back to life.
I also see a huge sudden increase of my water bill.
I get my water bill once every two months and here's what my consumption looks like
01/20/10 - 0
02/19/10 - 0
05/14/10 - 1
08/06/10 - 6
11/03/10 - 5
02/28/11 - 1
05/13/11 - 134
The house was being build till end of March 2011 so that's why there's no water usage. I didn't move into the house till early June 2011 so the water bill for May looks accurate to me.
This is a brand new house with 2 person living in there, and I have an irrigation system installed around June 10th 2010 (last year). I guess I should be kind of surprise that my last August bill is kind of low consider I watered twice a day, 15 minutes each zone and I have 5 zones.
My question would be what are the chances that my water meter was misread for the past few bills and now it is corrected? It is just mind bothering that the water meter is brand new and it is one of the that can be read wirelessly so how could it get misread?
dc638 is offline   Reply With Quote
Water Mystery - Sump Pump Set Right? robertr4836 General DIY Discussions 4 02-13-2008 02:32 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
