Old 05-23-2012, 12:28 AM   #1
water in basement
i have water coming out of basement drain .not sewer water and all the cracks in the basement floor are very wet. sewer is working fine this is out of town
steve e g is offline   Reply With Quote
Old 05-23-2012, 06:31 AM   #2
water in basement
Where does the floor drain pipe go?
You need to be sure that rainwater does not accumulate against the sides of the house. This may mean putting extenders on the gutter downspouts or even regrading the land around the house. Simply putting down a layer of gravel around the house will not fix the problem.
Do you have a sump pump and perimeter drain system? If you already have that it is possible that the drain pipes are clogged. A sump pump with no under-floor perimeter drain pipes is usually not good enough.
Perforated pipe perimeter drain systems can be either just inside or just outside the foundation, below basement floor level, with the outside system giving slightly better performance. Both kinds of systems demand that the water be removed, either by flowing underground downhill some distance to somewhere, anywhere, else, or accumulating temporarily in a pit to be pumped some distance away from the house before the water level in the pit gets higher than basement floor level.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 05-23-2012, 06:38 AM   #3
Super Moderator
water in basement
Sounds a lot like your sump pump has failed---high water table?
More info needed---
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 07:24 PM
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 11:08 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General Discussion 18 08-29-2011 09:34 PM
Advice for a novice: Mold and water damage in basement xoxJanette General Discussion 1 12-29-2009 07:54 AM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
