Water Backing Up The Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2009, 01:54 AM   #1
Down To Earth
asian432003's Avatar
Water Backing Up The sink
I have problem when I use the waste disposable turn on with water running on the upper level for couple minutes then the sink in bathroom on lower level water come out in the drain pipe until I stop run the waste disposable and the water on upper level so it stop.
Normal use with out run the waste disposable then everything fine.
Any help or Ideal would be appreciate!!!
asian432003 is offline   Reply With Quote
Old 09-06-2009, 04:56 AM   #2
Familyman
1. Is this an in-sink erator
2. Is it upstairs or downstairs
3. Have you tried a different combination other than what you posted, such as running all the sinks at one time and the showers.
4. Have you looked at your vent.
matt700 is offline   Reply With Quote
Old 09-06-2009, 10:09 AM   #3
Down To Earth
1- I don't know is an in sink ??? but problem I have when I use under sink disposable waste on the upper level with water running then I have the bathroom sink plug up with water??? I tested it so many times (only running water and under sink disposable waste that does that).
2_ It is up stair and down stair which is run on the same pipe.
3-Yes, I tried to open all the faucets at once (no flooding) it works good.
4-I don't know about the vent and how do I look for ??? Can you help me with that.
Thanks Matt!
Old 09-06-2009, 12:52 PM   #4
It sounds like the 2 sinks share a 1 1/2" or 2" drain stack and you have a partial blockage and it needs to be cleaned.
plumber Jim is offline   Reply With Quote
Old 09-06-2009, 07:52 PM   #5
Down To Earth
Yes, maybe ....should I call plumber to do it or it's just an easy one to DIY?
Thanks Jim!
Old 09-06-2009, 11:30 PM   #6
Well, If i was to guess you will need to pull the p-trap from the lower sink and run a cable (snake) down it. You can rent one if you know how to do it or just call a drain cleaner.
Old 09-07-2009, 08:08 PM   #7
Down To Earth
Thanks Jim!
Can you tell me where is the P-trap?
Old 09-07-2009, 08:47 PM   #8
Originally Posted by asian432003 View Post
Thanks Jim!
don't take this the wrong way , But if you need to ask that then its best you just call a plumber.
Old 09-07-2009, 09:14 PM   #9
Down To Earth
I think, I need one.
Thanks for advice!
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
water backing up in my tub jjenn84 Plumbing 18 04-08-2009 02:24 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
