Old 04-05-2009, 02:20 PM   #16
water backing up in my tub
they said they have had problems with there flushing. that there toilets are not flushing like normal
jjenn84 is offline   Reply With Quote
Old 04-05-2009, 02:24 PM   #17
Hmm, If they are able to still flush and thier water doesn't backup into your place then you need to have your pipe snaked from you unit to the septic. now if they can't flush thier toilets because they will backup someplace or overflow then it could either be the septic or a common drain line plugged.
plumber Jim is offline   Reply With Quote
Old 04-05-2009, 02:31 PM   #18
ok.. well thank you for your help. I guess i will see what it is really tom when they come out...
Old 04-08-2009, 03:24 PM   #19
WEll we had the septic people come out yesterday.
and our problem is solved.
The entire septic pipe line under the house leading to the septic was clogged up.Of course they did not charge me for it. They said it looked as though it has been from years and years of build up with what looked like powder detergents and grease. It just finally could not get anything else through it.. They snaked the pipe all the way to the septic and now everything is flowing fine.. Thanks for everything.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 06:11 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
