Old 06-08-2006, 09:00 PM   #1
Water backing up
At times when I run the washing machine and it drains, the toilets will not flush(they simply fill with water and overflow to the floor). The bathtub fills up with the water from the washer, and sometimes the water even backs up and comes from the bottom of the toilets and floods the bathroom. I plunge for a while at one of the toilets and finally all the water appears to drain. Then the problem goes away for awhile, however, there is always a gurgling sound in the master bath when the washer drains. Any ideas what could cause this to happen.
EB92246 is offline   Reply With Quote
Old 06-08-2006, 09:02 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Water backing up
The mainline that these fixtures connect to is clogged up, or if on a Septic Tank, it could be full, either get the mainline cleaned out or have tanj checked out if on a septic.
Ron The Plumber is offline   Reply With Quote
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
