Old 03-15-2009, 03:06 PM   #1
Water back up in basement
My basement has a drain in it and on several occasions it started to back up and overflow with water. I noticed it once and turned off the water supply which is located in the basement, but the water kept coming up thru the drain. I called the plumber and told them what happened and they actually called the city water company who came out and check'd the sewer near my home, but didn't see anything. Are there any suggestions as to what may be causing this. I'm tired of sweeping water up!!!
49erfootball
49erfootball is offline   Reply With Quote
Old 03-15-2009, 03:12 PM   #2
GC/Master Plumber/Mech
Call a different plumber that can rod/snake drains out and have then run the main drain to the city connection.
Old 03-15-2009, 05:17 PM   #3
Even though the City checked the sewer "near your home", they didn't check your main drain line. You have a clog that needs to be augered out. Hopefully, it isn't tree roots or a broken line that is sagging and catching waste to form a clog. You may opt for a company that has cameras to see what the real problem is.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
Basement faucet- Hot Water not coming out SpringfieldMike Plumbing 8 01-24-2009 09:42 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Controlling Water in basement greger Building & Construction 3 06-16-2008 06:56 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
