Old 10-08-2012, 07:17 PM   #1
Water arrester device
Is it really necessary to use a product made or can you just use pipe extended 12 to 18 inches upward on each leg?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 10-08-2012, 08:01 PM   #2
Persona Non Grata
VIPlumber's Avatar
Sure you can use a job made one, but why would you want to?
VIPlumber is offline   Reply With Quote
Old 10-08-2012, 08:03 PM   #3
call me E
TheEplumber's Avatar
Here is an answer by a water hammer arrester manufacturer
http://www.siouxchief.com/Resource_/...FAQ%204-04.pdf
Old 10-08-2012, 09:05 PM   #4
The house is a 1960's with galvanized piping and has "on the job" type installed throughout. We are remodeling a master bath, as a start, and I was wondering about duplicating what is there already.
I guess the answer to your question is, cost.
Old 10-08-2012, 09:06 PM   #5
Thanks, would you expect the manufacture of something to say anything different?
But it is a good read and informative.
Old 10-08-2012, 09:10 PM   #6
call me E
Thats why I said it was a manufacturer, but still... I believe every thing in that file. I will not make an arrester.
You can unscrew your chamber and use a Sioux Chief model that has threads- or not and add some under the counter later
The Following User Says Thank You to TheEplumber For This Useful Post:
digitalplumber (10-08-2012)
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 08:14 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
