-   -   Water (http://www.diychatroom.com/f7/water-85113/)
Kimberly1082 10-28-2010 09:28 AM
Water
I have no hot water pressure in my kitchen sink at all and no cold water pressure in my sink Upstairs in bathroom. We recently in July bought a new hot water tank.
Would the pipe going into the top of the tank have anything to do w/ the pressure if they are in wrong?
What could cause this? The pressure is fine in shower, laundry room sink (which is in same room as tank) and washer.
HELP!
Ishmael 10-28-2010 11:23 AM
The screens on the aerators are probably clogged. Unscrew the aerator from the end of the spout, and clean them out.
http://img.alibaba.com/photo/5168290...Restrictor.jpg
Kimberly1082 10-28-2010 11:55 AM
Thanks, but it was fine b/f the new water tank and after that it started. Its been this way since July..just been busy! :huh:
Ishmael 10-28-2010 12:10 PM
When pipes are cut and patched (as when replacing a water heater) scale, rust, dirt etc - not to mention solder, soldering paste, bits of teflon tape, pipe dope - can break loose from the inner walls of the pipes and get stuck in the aerators and flow restrictors. Did you check them?
Kimberly1082 10-28-2010 12:18 PM
We haven't, but someone said taht where the Cold is on HOt and the Hot is on Cold that it messed it up and possibly the whole tank. :eek:
Ishmael 10-28-2010 12:33 PM
Ah...missed that part. Although that needs to be corrected, it shouldn't "mess up" the tank, and it really shouldn't have any direct affect on the water pressure. There's a dip tube on the cold water supply inside the tank. As you use hot water, you're drawing the water off the top of the tank, and cold water comes in at the bottom of the tank - through the dip tube - to replenish the tank (if it were all piped correctly).
In your case, your cold water is entering at the top of the tank, and you're pulling hot water from the bottom. It's certainly not going to work as efficiently as it could; you're probably not getting as much hot water as you should, AND that dip tube is sucking any sediment that may settle at the bottom of the tank up into your hot water supply and clogging those aerators.
Kimberly1082 10-28-2010 12:37 PM
So the aerators are what puts out the pressure?
the_man 10-28-2010 05:11 PM
If every faucet isn't affected, then its not the tank. When 1 or more fixtures are causing problems, you need to start with the aerator. It has a fine screen that can catch debris and restrict the flow coming out of the spout. If its not the aerator, you need to take the faucet apart and make sure nothing is inside. If its not the faucet, you move to the shut off valve under the sink and make sure nothing is blocking it. Basically you start at the end and work your way back to the water lines. Aerator is the easiest and most likely place to start
Kimberly1082 10-29-2010 08:44 AM
The kitchen has Cold pressure and not HOT and the bathroom sink Upstairs has HOt pressure and NO cold.
del schisler 10-29-2010 09:17 AM
aerators don't put out preasure. they are i belive reated for so many gal's going through them. tho I bet the screen's are pluged. take them out and see . Once they are out turn on the faucets let them run a little.
Ishmael 10-29-2010 09:31 AM
Then it's most likely the respective hot or cold stem or cartridge in each faucet. Often the rubber washer inside the shut-off valve under the sink can break down/disintegrate over time, and the little pieces of rubber can become lodged in the stems. It's an easy job for a plumber or handyman, but if you're not careful or good with tools, you can open a can of worms.
Kimberly1082 10-29-2010 11:38 AM
Thanks everyone so much for their help. I will give this to my handy man hubby and see waht e can find out. I will post on Monday!:thumbsup:
Kimberly1082 10-29-2010 11:39 AM
Thanks for taking the time to give me some options.
