Waste-vent Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-14-2013, 10:07 AM   #1
Waste-vent stack
Hi,
I have a quick question. When you have a 2 story home or lets say a first floor with more than one bathroom is it normal to have more than 1 waste/vent stack that goes from the roof to the basement?
mmiller is offline   Reply With Quote
Old 04-14-2013, 10:32 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
Originally Posted by mmiller View Post
Hi,
Let's say it's not abnormal. Stacks are located near the fixtures served. If it's convenient to the plumber to have more then one stack- so be it.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-15-2013)
Old 04-14-2013, 10:49 AM   #3
Yes but what if a fixture or two or not close to the stack?
Old 04-14-2013, 10:57 AM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 990
Did i go back in time, was int this question already asked and re asked.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following 2 Users Say Thank You to Javiles For This Useful Post:
ben's plumbing (04-15-2013), TheEplumber (04-14-2013)
Old 04-14-2013, 11:12 AM   #5
Plumber
Rewards Points: 452
Then you run drain lines to that fixture, and properly vent it.
Old 04-14-2013, 01:06 PM   #6
Yes and if its too far from main stack what is the proper way to vent it?
Old 04-14-2013, 01:41 PM   #7
Rewards Points: 2,516
Either back to the vent stack, above the flood rim of any fixtures on upper floors or run a new vent stack out the roof.
Take your pick.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Old 04-14-2013, 01:41 PM   #8
http://www.plumbersurplus.com/Prod/S...r/6103/Cat/232
jsbuilders is offline   Reply With Quote
Old 04-14-2013, 03:59 PM   #9
Take your pick.
Ok I got that part. Now if you have fixtures that are a long distance from each other is it normal to have more than 1 waste/vent stack?
Old 04-14-2013, 04:09 PM   #10
Plumber
Rewards Points: 452
A stack is simply a way to get the waste to a lower level. You could have 6 of them if you wanted.
Consider a slab on grade home- it has no stacks and it probably has multiple ventes through the roof.
Old 04-14-2013, 06:21 PM   #11
I understand that and I am just asking is it common to have more than one waste/vent stack in a house? A slab foundation has no stacks? Why is that?
Old 04-14-2013, 07:38 PM   #12
Nothing to do with being common. Has to do with being functional.
Old 04-14-2013, 07:56 PM   #13
Is this true that slab foundations don't have waste/vent stacks?
Old 04-15-2013, 01:17 AM   #14
Always learning...
fetzer85's Avatar
Rewards Points: 262
You've asked 8 questions, our turn.
Do you have any knowledge of DWV systems?
Why are you trying to find out if multiple waste stacks are normal/common?
Why do you keep repeating your questions?
As already stated, the number of stacks/vents depends on the style of house and the placement of fixtures.
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
hammerlane (04-15-2013)
Old 04-15-2013, 09:34 AM   #15
Yes I do. This is a forum, correct? Is it illegal to ask these questions? And NO that was not stated before but thanks.
Removing/Replacing Cast Iron Vent Stack to Polyurethane-Inject Leaking Foundation Cra greenfrog5 Plumbing 2 12-05-2012 11:21 AM
Have a photo of my waste stack; suggestions concerns? langless28 Plumbing 12 10-12-2012 09:12 PM
Can I install a basement toilet directly into soil stack and without a vent? oaktowngrrl Plumbing 3 01-28-2011 01:42 PM
Vent stack for kitchen sink stan 41943 Plumbing 19 03-16-2008 06:50 PM
leaking vent stack joint xrayman Plumbing 10 03-04-2008 04:23 PM
