Waste Pipe Routing Query - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2010, 04:52 PM   #1
Jol
Waste pipe routing query
I have inherited a DIY project and have some questions regarding the whys and wherefores of routing waste pipes around the bathroom. You can see from the attached doc that we plan to install a bath, basin, shower and toilet, with a pre-existing waste pipe fitted into the corner of the room, which runs to a vertical stack, via another bathroom, some 4m away.
Can I simply run one waste pipe from the bath, via the basin, then to the shower, combining all 3 wastes into one, then under the doorway to the main waste pipe, into which the toilet is plumbed? Or do I need separate pipes for any appliances?
I need to cross the joists at some point - do I simply notch them or should I be drilling holes?
Will I have flow problems, given that the total run is going to be in the region of 6m?
Grateful for any thoughts/advice.
Jol is offline   Reply With Quote
Replacing a Cast Iron Waste Pipe Beylah Building & Construction 0 01-18-2010 02:42 PM
water running down waste pipe rav927 Plumbing 5 07-04-2009 09:24 PM
Waste Pipe Replacement Handymom2008 Plumbing 5 11-24-2008 10:49 AM
Toilet Bowl to Horizontal Waste pipe BOBC Plumbing 3 08-30-2008 01:17 PM
waste pipe leveling issue amakarevic Plumbing 9 03-27-2008 05:12 PM
