-   -   Waste pipe odor in garage? (http://www.diychatroom.com/f7/waste-pipe-odor-garage-4927/)
Kirsten 11-20-2006 11:57 PM
I have recently pulled all the drywall in my garage ceiling and walls due to a rodent infestation. Much of the upstairs plumbing is now exposed, including the waste pipes for two toilets, a tub, shower and three sinks. The main waste line comes down a now open wall before exiting into the crawlspace. I mention all this because there is a distinct toilet odor in the garage and I am convinced it is coming from a crack or hole in a waste/ vent line. It does not smell like like septic effluent or what I think of when I think of sewage odor, it smells just an outhouse or a around a leaky toilet flange. It is definitely human, not rodent or cat. I suppose it could be a leaking flange, but we reseated the toilets a couple of months ago (because they were loose - but no obvious signs of leaking when we pulled them) and I see no water staining under the subfloor presently.
I have only owned the house for three months, so I do not know how long the odor has persisted.
How can I figure out where the odor is coming from/ if there is a crack or leak in a line? If I call a plumber, will this be a long expensive process? I am needing to close up the drywall in two weeks, so it's now or never. I definitely don't want to close up septic gas in the walls/ house.
Thanks for any advice you can give me.
joasis 11-21-2006 06:02 AM
You have a hole somewhere, allowing venting into your garage. If you can't see an obvious problem, then you really should call a plumber...it should not be a big job to locate this, but if let go, could have health issues as well as making your house unlivable.
My neighbors had a persisitant sewage (outhouse) smell in their house...just a creep in kind of smell....turns out a cast iron pipe behind a toilet (vent stack) has a rust through hole in it....no big deal, but on windy days, the air would come down the vent (slight pressure) and the house would stink.
Kirsten 11-21-2006 12:04 PM
Thanks joasis.
Can you or anyone else tell me what is involved in investigating the leak? Are we talking about a smoke test? vbmenu_register("postmenu_24327", true);
joasis 11-21-2006 12:07 PM
Smoke is the correct way, and a plumber will have the stuff to do it with.
