Is This A Waste Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-03-2010, 01:43 PM   #1
Question
Is this a waste pipe?
Hello,
All zero of you who are dedicated followers of my posts will recall my previous question about installing a new disposal under my sink.
Water leaking from under disposal/Installing new disposal
(You don't really have to read that to follow this question, but it's there for context.)
The point is that under my sink the waste pipe is mounted very high up making it difficult to install a disposal because it means that the drain hole from the disposal is not above the level of the waste pipe, meaning that water doesn't drain out of the disposal.
I recently ripped out the floor of the under-sink cabinet because they were all rotted and underneath was some linoleum flooring, with an odd capped pipe sticking out from the floor.
So I begin wondering if this pipe was a waste pipe. If it is, then my under sink plumbing problems might be solved because I could just have the drain from my sink/disposal run out of that pipe, right? Does anyone know if that is a waste pipe and/or if there's a way to test/find out?
Thanks again to all.
quadari is offline   Reply With Quote
Old 08-03-2010, 01:45 PM   #2
Could be a gas pipe
Old 08-03-2010, 09:07 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 444
I'm thinking its an abandoned drain line from an old s trap. If so, why was it abandoned? Best not to use it. Could be rotted, clogged or the other end may be open.
Old 08-03-2010, 09:23 PM   #4
Owner
LateralConcepts's Avatar
I agree. Could also run to a dry well which has been abandoned depending on how old the house is. You should be able to tell since it's on the interior of the home and not in a wall. Can you see it from underneath? I mean in the basement.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-04-2010, 12:37 PM   #5
The building was built c1920 (as far as I know). It's actually a condo building, but fortunately I'm on the "first" floor. (First is in quotes, because I'm not on the ground level, you have to come up one flight to my unit, but below me is the laundry room/storage area.) So I might go poke around the laundry room and see if I can figure out where that pipe goes.
Thanks.
Old 08-04-2010, 12:58 PM   #6
What is the diameter of the pipe ?
1"....1.5" ?
Old 08-05-2010, 09:19 AM   #7
57_Hemi's Avatar
Thanks.
Considering ur on the "first floor" with a laundry room below... that might be tied into ur drain and the others above you and "might" be used as a cleanout of some sort.
Only reason I say this is b/c the buildings I've worked at...... all units on 1st floor located above the basemnent laundry room had cleanouts under thier kit & bath sinks because the drains either 90'd (or 45'd) along basement ceiling (below 1st level....floor) towards the wall due to the fact that the laundry room was a big open space and they had to redirect the main stacks towards the outer walls.
hmmmm...... maybe ask ur condo maintenance person (if there is one) and see what he/she says.
let us know
57_Hemi is offline   Reply With Quote
Old 08-05-2010, 10:03 AM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Might even be a cleanout for the kitchen drain.
Journeyman Plumber
Old 08-05-2010, 05:45 PM   #9
Retired Plumbing Cont.
Don't touch it. It was abandoned for a reason. Even if you could use it the only way would be with an S-trap (not legal). Who needs a disposal anyway? Even though I've sold and installed a train load of 'em I don't have one in my house.
rockerjockey is offline   Reply With Quote
Old 08-05-2010, 06:25 PM   #10
Owner
You're better off opening the wall and lowering the sanitary tee. It's simple. Cut out a section of the old galvanized with a sawzall, slap your new san-tee in, and secure it with no-hubs.
Lateral
(208) 818-8241
Old 08-05-2010, 11:58 PM   #11
Rewards Points: 352
Take off the cap and put a hose in it, Lets see what happens! You can always put the cap back on if you don't like the results. It will be fun an adventure.
plumberinlaw is offline   Reply With Quote
Cutting into Cast-Iron waste pipe. dOe Plumbing 4 03-29-2010 07:09 PM
Sewage smell from internal waste pipe jellybean11 Plumbing 3 03-17-2010 10:10 PM
Waste pipe routing query Jol Plumbing 0 01-28-2010 05:52 PM
Replacing a Cast Iron Waste Pipe Beylah Building & Construction 0 01-18-2010 03:42 PM
Waste Pipe Replacement Handymom2008 Plumbing 5 11-24-2008 11:49 AM
