Waste & Overflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2008, 04:40 PM   #1
Waste & Overflow
Do all tubs have to have a waste and overflow? I am have a spec for a japanese soaking tub that does not have a waste/overflow. Any opinions????
khb123 is offline   Reply With Quote
Old 08-05-2008, 07:06 PM   #2
Thumbs down
It is code required in Canada. I personally wouldn't install a tub without one, especially if you have kids. The reason for the overflow is in case you fill the tub up to take a bath and you somehow forget about it, no overflow = water coming through ceiling from below
pauly-o is offline   Reply With Quote
Old 08-05-2008, 09:36 PM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Not required here, so no not all do, I did one long time ago, no overflow just the drain on the bottom of tub.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 08-06-2008, 12:01 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
there are no (new) mobile homes with overflows. The only time you see them is if it's been remodeled. I guess the mobile home plumbers can't figure out the waste/overflow kits so they just omit them and cover the overflow hole instead.
Journeyman Plumber
Gate Valves or Stop and Waste Valves Rich Plumbing 5 03-03-2014 03:29 PM
waste pipe leveling issue amakarevic Plumbing 9 03-27-2008 06:12 PM
anti freezing stop and waste valve leaks James Parsons Plumbing 1 10-07-2007 03:11 PM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 01:07 PM
External Waste Water Drain alangan Plumbing 1 08-11-2005 08:42 AM
