-   -   waste line in basement slab (http://www.diychatroom.com/f7/waste-line-basement-slab-33412/)
7474 12-08-2008 03:40 PM
Moving toilet location in basement slab.
I have removed all the concrete and am ready to move the waste pipe for my toilet. I currently have a Sioux Chief TKO toilet flange (model 883-AT) installed and I will be replacing with the same. www.siouxchief.com/PDF/TKO-Brochure-4- 05.pdf
This flange can go inside 4" pipe or over 3" pipe. Hopefully I can explain this properly. Currently, the set-up is the flange is installed inside a 90 degree elbow with 4" opening that reduces to 3" that connects to the waste line. The problem is that I cannot find this 4" to 3" reducing elbow at Home Depot or Lowes. Is it OK to simply put the flange over 3" pipe or is there a reason it is set-up this way in the basement slab? The set-up on the other bathrooms I have is the same flange goes over a 3" 90 street elbow connecting to the waste line. The basement slab install is the only one that connects into this 4" to 3" reducing 90 elbow.
Thanks for any assistance you can offer.
7474 12-10-2008 04:53 PM
Figured it out on my own....
For those that looked but didn't know and might be interested for their own future use.
The 4" to 3" elbow was so that a 4" pipe could extend above floor level before the concrete was poured. Then the 4" pipe was cut flush to the newly poured floor and the flange was dropped in. Couldn't be done with the 3" pipe sticking out of the floor as it would have been surrounded by concrete not allowing it to be solvent welded inside the flange.
DangerMouse 12-10-2008 05:29 PM
darnit, that's what i was going to tell you too......
DM
majakdragon 12-10-2008 07:48 PM
Whoever installed the plumbing must not be aware of styrofoam or foam rubber collars to place around 3" pipe for this. The collar also protects the PVC from damage by the concrete. When ready, you just cut out enough material to install the flange. Glad it all worked out for you, and thanks for the update. Always nice to know how things worked out.
7474 12-10-2008 08:04 PM
Thanks for the information regarding the collars to place around the pipe. I have not completed the task yet so I will look for these at my HD or Lowes.
Thanks again.
wrangler 12-11-2008 06:30 AM
And don't be scared to go to a plumbing supply store. They will always have a bigger selection than HD/Lowes and usually better pricing.
7474 12-11-2008 06:38 AM
Thanks, appreciate the info.
