Waste Ejection Line Tie-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-19-2011, 01:45 PM   #1
Waste ejection line tie-in
I have a detached garage with a finished upper. Currently no water supply or drain. Residence has lift station in basement that ejects all waste 200 feet to street with 15' head. I want to get a small bathroom in the upper of the garage. Is it acceptable to install a second station in garage lower that ejects to a wye tied into the main ejection line of the residence about 50' from the residence station? Of course a check valve ahead of the wye at the second station just like the check valve in the residence. Pump in second station would be slightly under-rated of that in the residence. Any comment appreciated.
jmarro is offline   Reply With Quote
Old 04-19-2011, 02:57 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Depending on the distance and grades involved, I would be tempted to gravity feed from the garage to the existing ejector pump. Adding a 2nd pump doubles the maintenance.
Coastal South Carolina
Old 04-21-2011, 01:38 PM   #3
That will probably be the route I take. The existing station is lower level and downhill from the garage. Dealing with Minnesota frost line, so some major digging along with electric and gas to cross...thanks for the comment!
Old 04-21-2011, 07:06 PM   #4
Owner
LateralConcepts's Avatar
Just an FYI - April is safe digging month! Call 811 before you dig. http://www.call811.com/campaign-mate...ing-month.aspx
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 04-22-2011, 01:29 AM   #5
Oh I will.... Several years ago I managed a high pressure gas line, (thankfully a check valve about 200 feet away), with a backhoe. So when they say hand dig make sure you open it up a bit; can never be safe enough. Very fortunately, the only pain was in my wallet.
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Questions regarding AC coil condensate line lassiter1979 HVAC 1 03-14-2010 09:47 PM
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 10:55 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
