Washing Maching Drains? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2008, 07:48 AM   #1
My washing machine drain broke under the slab, and while thinking about how to repair this, I would like to know if there is a P-Trap in this drain?
Savingmoney is offline   Reply With Quote
Old 10-03-2008, 07:52 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
I don't know if there is a P trap but there certainly should be (and it is code required). That being said it is not normal to put a washer stand pipe trap under the slab.
Old 10-03-2008, 07:56 AM   #3
Registered User
Termite's Avatar
Yes, there should be a trap for the washing machine drain, as well as a vertical standpipe above the trap at least a couple feet tall. The piping should be 2", no smaller.
It is good to install the trap in an accessible location (as you've found out).
Probably going to have to break a little concrete unfortunately.
Old 10-03-2008, 09:21 AM   #4
Traps are required on washer drains. Since you are not seeing one on your pipe, it is doubtful one was installed. Older codes called for 1-1/2" drain lines but with the more powerful pumps on washers, 2" is what most areas now require.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
How are cast iron drains? Do you have to plunger them often? twilightcall Plumbing 4 08-29-2008 12:07 AM
replacing old galvanized drains drewhart Plumbing 18 07-20-2008 12:14 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
Washing Machine Drains to outside in woods? Options? twilightcall Plumbing 13 01-14-2008 01:48 PM
